sir @xulfiqar today i picked my calibrated pump and nozzles. they said my pump was working fine and did not had any issue.
I asked them for checking the CSD, they said they don't have water connection to check it ? this disappointed me.
anyways to check whether its working or stuck in rust first i poured boiling water in the CSD through a pipe and kief but there was no change in CSD plunger, so i took it to a roadside mechanic nearby, asked him to dismantle the CSD from pump and check it, he was opening it first time still i asked him to proceed as i was getting it done in my presence and mechanic was not allowed to touch any other thing on the pump, so he used L key and dismantled the CSD, now one more nut was unscrewed and the 2 heavy springs too came out.
now i took the CSD from him, put it in a bowl, poured full water in it and put it to boil, after 5-8mins the water started boiling still there was no visible difference in CSD plunger coming out, there was just a very tiny difference upon close notice that plunger came out.
now we let it cool down and i asked mechanic to pull the plunger out, it came out with a 'phuk' (like its air tight) sound and was very free inside, then i asked mechanic to pull out the thing in which that plunger was moving but that did not came out.
so we decided to reassemble the CSD and now we were not able to put back the 2 big springs and the piece attached to it which plunger moved and pump is still in same condition.
now please tell me how to check CSD is working or not and how to put it back ? tomorrow I will get the pump installed back and will also get timing belt changed.
