@Xulfiqar SOS
My Diesel Nissan CD17 (overhauled in 2017) working well, now cold starting problem.
The problems initiated few days ago. I dont know due to my "chhairkhani" or something by itself.
The problem is that the Engine runs well but when I start it usually took 3 heaters and few revs to start. Now it takes 3 tries on self ignition and a push on the pedal.
NOTE: I went to the mechanic and he diagnosed that 2 heaters are gone faulty. I replaced them, a little bit betterment is seen but it still takes 2-3 tries of long self and then a push of pedal to start. Before this it never needed a pedal push.
I believe that the diesel intake pipe is taking bubbles with it when i pull the throttle, when the engine is on.
Battery is new, charged, fixed properly.
2 Heaters replaced.
Can it be a compression issue? OMG I have not pushed it to its limits that it has developed comppression issues, I just drive it like an old baba g. I fear anytime its bones can break so i dont think it can get compression issue. what do you suggest.
engine oil was black and lubrication was good and it only ran 2000KM hardly.
My Diesel push pump is not replaced since 2017.
