Agreed. But after 10w-40, 15w-40 is available in some brands, like ZIC for example; https://zicoil.pk/product/zic-x3-15w-40-vhvi-tech/
Change the oil grade first. Use 5w40 or 10w40
u need to check if the engine is weak or there is some leakage. open plugs and see if there is any oil residue on it. u can also check blow from oil filling cap. and the most authentic is compression test. i dont understand what the company guys will do after opening engine when u can tell the condition without opening it. changing oil a to b and switching between fully synthetic and semi synthetic has certain precautions and side effects.u r in which city ? RYK or RWP
I m in District Ghotki near RYK...what r the signs of weak engine ? I just travelled 1000 km yest and it gave me no problem (except eating engine oil)...i m thinking of changing oil grade
already mentioned above. oil on plugs. blow with white smoke. weak compression
dont change oil grade yet, first diagnose the issue what oil grade u r using now and since when ?
I m using Honda Genuine oil 10w30 when car completed 1 lakh KM nearly 1 yr back...engine does not emit any smoke...n yes no oil on plugs as i did regular tuning this july...so left with 2 options i.e change grade or open engine as pistons may have issues (as mentioned by Honda)...i will try changing grade and keep engine option as last resort..i will welcome any third option if u have any
the statement of honda to open engine is wrong .. do not do that .. call me .. cell no in inbox
check the link above for info on compression test
Meri b same problem ha,apka issues resolve hoa ya nae?Honda city 1.3 (2014), I'm using atlas 10w-40, my mechanic is saying switch to 20w-50,if the problem remains there then we have to change engine.click image to check oil level.
