@umans
Lets see whats happening with your cooling system:
I could be right or I could be wrong.
From your previous replies: (Current status)
1)The radiator fan is automatic (using coolant temp. sensor)
2) Temperature needle remains in the middle in the city driving.
3) Thermostat valve removed. (Suppose to cool the engine continuously, since you have removed the thermostat valve and there is no coolant stopage. But the question is does your radiator fan turns on when the coolant temperature goes up or when AC is running).
Whats happening????
Do you also know that CNG ignition temperature is 700 deg C which is a lot hight than petrol (455 deg C).
i) On motorway temperature needle moves upward form the middle with AC and 100-110km/h
(So, when you drive under AC load @110km/h with higher rpm engine gets hotter and you see the temp. needle moves upward. I do not know why your temp. needle moves upward, air through the front grill + the AC or radiator fan should keep the temperature in normal condition. May be your fan does not come on with AC, you have to check that).
ii) If speed is reduced to 90km/h or without AC temperature needle becomes normal.
(When you drop the speed to around 90km/h ofcourse with less rpm than 110km/h your coolant temperature drops because less heat generated by engine at low speed. Hence, you see the temperature needle comes to normal range.)
iii) In city driving temperature needle remains in the middle.
(In city driving usually you don't go at high speeds therefore engine temperature remains normal or in the middle.)
You have not mentioned that at 110km/h with AC how high the temperature needle goes. Does it stay above normal or it just keeps going near the red zone. Do you have two fans on the radiator??
All your symptoms looks okay to me. Its just the CNG burning hotter than petrol. But I would still double check if the radiator fan or AC fan if together are working fine when the temperature move up.
You can also try a coolant mixture of 70%water to 30% glycol due to the hot weather. It will help a little bit to bring the temperature down. Boiling point of the mixture will still be around 135.55 deg C
@digimanpk
I tried my best to understand the symptoms which @umans mentioned. Lets see what happens. I hope that his engine temperature problem will be solved. (H)
@FM01
if you are listening to me, help us out , wont you??
I tried
