@umans
Yaar Engine coolant change karna koi itna bara basla nahi hai. buy a screwdriver , and remove the clamp from the bottom hose which connects to the radiator,remove the hose from the pipe which connects the hose and the engine. Now let the water drain. open the radiator cap so that all the coolant drains out. Now connects the hose back and tighten the clamp. drain the overflow bottle as well. Fill the radiator with water. cap the radiator idle the engine for 5 min. Drain the water. Repeat the process. and drain the water again. Then fill it up with coolant.
Cant recommend any coz I run my car on Tap water ..lolzz.
Buy a branded ones. Caltex, Taxeco, Shell, PSO. Buy a pre mixed one if you have to.
Acha haan, aik kaam to karo. The second time you put water in the radiator as mentioned above. Dont drain it just after idling the engine. Run the engine on highway and check if its heating up again ??. Dont put ordinary tap water in. Buy distilled water ( Water from A/C drain).
If its heating up again. There might be some mechanical problem with your engine.
Aur yaar engine main kidhar say awaz aarahi hai???. konsa aisa bearing hai jo mechanic nay ok kar diya hai. Kahin tumhara water pump to nahi hai mere dost??. Jo bhi ho , pay attention to it coz you know chotee chotee problem baad main kitna bara masla kar daitee hain. Get it resolve.
i'm realy fedup from this crap made by Susiki..................
Yaar, I know , buying a cheaper car or an expensive car is the same. Expensive car saal main aik dafa kharab hotee hai , Cheap saal main 10 dafa. And you end up paying the same amount at the end of the year.
