@displacement_on_demandnow i m back
First of all... I don't know why you and few other members get so "Mad" or "Red" when people reply to the posts... All I did was reply to your post and you are talking back as if I commited some fedral crime. Why is it that some members on this forum are always in a "fight" mood?
the reason is this all ppl cannot hav same mind but things get worst when a person neglects everything n stick with his point which other ppl dont like and things bcome more worse when everythings made clear as i did but some1 remain ignorant8o|8o|8o|8o|
I made things very clear... Direct connection to radiator fans isn't BAD. I don't know how cold it gets in Pakistan but here temps go down to almost -45 in winters and I have seen many
cars with 2 fans that have 1 fan as direct
hav u ever heard about thermostat valve dear????????
what it does is simply restrict flow of water so if 1 fan is kept direct (i dont know y ppl do this) engine maintain its temp by no flow of water
open ur eyes here
i m posting s thread here 4 performance n mileage n r talking about hi way :d:d:d:d:d:d:d:d:d:d:d:d:d
80% of ur driving is done within city n u ''hi way''
now listen by heart
on hi way i agree more air flow through radiator but dont forget 1 factor that more the speed means more work n more work more needs energy needed n more energy burns more fuel result in what ?????????
shit
no
it results n heat so car maintain its temp even on hi way also by usin thermo valve
ok my dear
now next
When you start up the car in morning.. the water pump only circulates coolant in the engine.. not radioator as the thermostat runs in closed mode but as the car starts to reach it's normal temperature... the thermostat starts to open, allowing coolant to flow in radiator.
You were talking about ECT (Engine Coolant Temperature) sensor. First of all.. ECT is usually located on cylinder head or on theromostat housing... What it does it read the coolant temperature and send signal to the PCM.
so whats the point to ponder i was hell tryin xplain the same
You are giving people wrong advice...
secondly work on igniotion coil a faulty ignition coil eats up power as well as fuel
If the ignition coil is faulty... the car won't simply start up... even if it does for sometime you would know right away about this problem...
u r right but lil bit
what is the transition b\w faulty n good ign coil
u r right that a faulty coil will not start engine but a ign coil about fail work will not produce shiny spark
a good shinny spark is needed to burn all fuel in cylinder a less light spark will not produce the desired spark result in wasted fuel n engine will suck more fuel to allure the itself to mileage drops here
nopw ok
is everything fine now or i hav to more ''''''''fight'''' replies
now get checked ur spark plugs
faulty plugs r main cuz of low mileage
faulty plugs dont lead to low gas mileage but they cause misfire...
i dont know who feeds u this stuff
now a faulty plug do not always makes misfire here r certain cuz 4 that
hav u ever gone 4 tunin n mechanic says '''' plug short hay''''
i m talkin about that short plug which never makes misfire but dcrease performance n mileage
this happen that u gone 4 tune up n mechaniic said
plug short hay but v u drove thousands of miles with out a single misfire
it happednd 2 dont know about u
i hav askd 'em dat it drive car but no prob n they say fell difff now n it lays thery it is coomon to listen after tunin car perform well due these reasons my dear
this is my last attempt to clear ur mind
if i failed then remain ignorant from my side
what else i can do
think on evrything will not lessen anything
