@crazyrider
Have u ever heard about thermostat valve dear????????
Yes I have... and have you ever heard or correct wording? Because thatās what you need...
Refer to it as thermostat not thermostat valve... If the thermostat is bad... what are you going to say... the thermostat is bad? Or thermostat valve is bad?
And yes I know what a thermostat does... here is a brief explanation... and this is what I learned in college...
The thermostat controls the minimum operating temperature of the engine. The maximum operating temperature is controlled by the amount of heat being produced by the engine at the time and cooling system's ability to dissipate heat. The technical definition of a thermostat is a temperature responsive control valve. The thermostat controls the temperature and amount of coolant entering the radiator. While the engine is cold, the thermostat remains closed, allowing coolant to circulate only inside the engine. This allows the engine to warm up uniformly and eliminates hot spots. When the coolant reaches the opening temperature of the thermostat, the thermostat begins to allow coolant to the radiator. The hotter the coolant gets, the more the thermostat opens, allowing more coolant to flow through the radiator.
So if the fans are on all the time... coolant is going to cool down much faster causing the thermostat to close/open more often. It makes the cooling cycle fast.
on hi way i agree more air flow through radiator but dont forget 1 factor that more the speed means more work n more work more needs energy needed n more energy burns more fuel result in what ?????????
More speed doesn't mean the engine is working hard... if you're travelling at 100km/h... the car is probably like in 4th gear... higher gears mean less load on engine... causing it to produce less heat...
i dont know who feeds u this stuff
now a faulty plug do not always makes misfire here r certain cuz 4 that
The word itself explains... "Faulty"
Faulty plugs cause the engine to misfire... worn out plugs cause low mileage... there is a difference....
If you drop a plug on ground and put it in the engine... it may be broken or faulty... and will likely cause engine misfire... not low mileage!
@spectra
The operating temperature is 101.6 C
@crazy rider
if ur fan is direct and still gauge goes to half it shows ur car is overheating bcuz as ur fan is on every time so engine
Wrong...
The temperature is controlled by thermostat... if the fans are direct... the engine would still reach its normal operating temperature...I don't think it goes down to -30 -40 in Pakistan... does it?
In Canada it does... and I have seen a few cars with both fans direct and a lot of Hondas with one fan direct... and they all still reach the normal operating temperature!
@digimanpk
Rs 650-700 for genuine Suzuki Thermostat valve. ( Most probably your mechanic has removed this valve as well so to make engine more THANDA!!!).
Rs ~100 for mazdoori.
Man it's simply called thermostat... Not thermostat valve...You can't just buy thermostat valve and insert it in the thermostat housing... You buy the thermostat whole... If the thermostat is faulty... You replace the the thermostat... not just the valve. Valve (piston) is just a small component in thermostat.
@crazy rider
what hapens in pk that our geniouis mechanics and electritians suggest that our climate is hot so it is better to use direct fan rather than auto fan which is tottally rong.
In a way they are right... In Pakistan, the roads are not so good and there is more stop and go traffic... the transmission changes gear more often... engine works much harder in stop and go traffic... They all cause more heat... Direct fan with thermostat is not a bad option considering hot weather in Pakistan.
u know every new car has auto fan nad thermo valve
All cars had thermostat since like 90's? Thermostat is a MUST even with direct fans...
@uzzyā¦
If your car has direct fans and it the gauges read 50% than your car is running prefect⦠In summer it shouldnāt take more than 2-3 minutes for the engine to warm up... In winter it can take up to 15 minutes.
And PLEASE everyone⦠get this thing⦠The engineās cooling system uses āCoolantā NOT waterā¦
