AoA Friends,
I have recently purchase Vitz FL-2003 in which CNG was installed, then I removed the CNG and started on petrol and in 2,3 days the head valve leaked. I repaired the complete head and became okay. Then I noticed some weird kind of noise in the engine and the mechanic told me that this is because of the power pump and replaced.
Currently, I am facing the following issues.
Leak Near Crank Pulley (Repaired twice with the mechanic but leaking again after some days)
Water coolant water is oily and dirty (The mechanic told me that it would be fixed in two, three-time changing the water)
The mechanic recommended me to fill coolant with Toyota coolants (Will I use coolant waters all the time ?)
There is a little leak of water beneath the gearbox (Two or three drops all the night long)
The engine fuel consumption is okay, about 13km/l in long drive, no smoke, no oil in the exhaust
Expert opinion is required, should I replace the engine or should I fix it.
Furthermore, can I close the ugly hole of CNG?
suggest an expert mechanic in Peshawar
