I tested compression on my honda city idsi 2004. Below are compression results.
Method used. Remove front four spark plugs and coils. Disconnect rear ignition coils. Hold throttle wide open. Cranked four time on each cylinder to get a reading on compression guage.
1st cylinder dry 160 psi
1st cylinder wet not attempted
2nd cylinder dry 90 to 95 psi
2nd cylinder Wet=150 psi
3rd cylinder dry 125 psi
3rd clinder wet=260 psi
4th cylinder dry 160 psi
4th cylinder wet =280 psi
I took 1st cylinder as the one closest to timing chain side.
These figures do not look good.
Should i go straight for an engine swap ? As rebuilding these engines is not advised by mechanics
