I am really thankful for your concern. I did pour the Toyota Engine Flush Additive and changed the oil after getting that warning second time. Also sump and strainers were also cleaned.
Present mileage is 136K. I will surely repeat the process as per your directions at 140K service.
In my view, synthetic oil removed all the sludge and accumulated it in the sump. I was just skeptical, if I use synthetic oil again, it is going to clog that drain too.
For the first time, I was rightly guided by my Mechanic for the first time after Toyota guys planned to open up the engine and qouted a long list of things to do for removing low oil pressure warning including oil pump change. But I didn't believe them and was sure that a Toyota Engine run with lot of care would not breakdown it's parts after only running 80Ks.
Second time, I just went to a roadside mechanic and told him to remove the sump and clean the strainer. Car was up in no time.
I would run a flush again surely.
@babaralinawab! How about putting synthetic oil before one oil change and then flushing before next change?
