^^Hard Clutch ...No Hydraulic PUMP???? I Am Not Getting Anything......!!
Don't Tell Me You Are Using Cable Type Clutch ........!! F**** NO....
For CNG.......I Warned You..That Fuel Line Leakage Is Due To Immature And 'Thuuk Se Chupkane Wale' Work These Installers Do
They Have Pretty Much Everything Available But Still They Are Just In Hurry Of I Don't Know What.....They Risk Everything for Sake Of Some Hundred/ Thousand Rupee......!
You Need To Double Check Fuel Lines When You Get Swap And Don't Use Normal Rubber Pressure Pipe For Fueling.....Petrol Will Soften It And Blow It Up....Never Ever Listen To Their Illogical Stuff And Use Sane Mind To Think And React.........!!
The Pressure Of Fuel Is enough To Spray Fuel Anywhere Inside/Outside Car And Things Can Change Dramatically Then..........Wire Up Fuel Pump With ECU As It Should Be.....!!
There Are Tons Of Things Which Need To Be Checked .....Its Mandatory As Per Risk Factor But They Just Don't Give A DAMN.......Engine Started It Revvs....Pay And Get The Hell Out Of Their Place Is Their Logic
