Guys recently i have installed Japanese EPS in my 2013 cultus. . the mechanic configured all the fittings and connections and installed the EPS keeping everything original.... its like company fitted EPS
steering is working perfectly fine even connected with speed and get harder when speed increases.. .
now the only issue i am facing is that steering is not completely returning back to original position on turns and you manually have to return it back to ZERO position. . . the mechanic said it will get better after use but is there anything i can do to make it better. . like greasing, alignment etc. . .
