Some one is in a habit of stealing petrol from my car.
Decided to do A DIY. Had a spare magnetic door sensor which uses a reed switch (wired part) and a magnetic part(non-wired part) to sense & trigger
Therefore decided to rivet the door sensor to petrol lid & connect its wire to door push button which switches the cabin lamp "on" & "off".
PROBLEM:
The door sensor works(alarm activates) when the magnetic part(non-wired part) is bought near the reed switch (wired part) where as it should do the opposite. i.e. the alarm should activate if the two parts of sensor are not in close proximity to each other.
I have also reversed the wiring contacts but the result is same.
I have searched on internet & found that security systems use a state called Normally Closed (N.C.), therefore if a someone cuts a wire the security system goes into a "Open" position and it triggers the alarm.
Therefore I ASSUME that I need to convert it into a default Normally Open (N.O.) state but dont know how to do it.
Any sort of help in this regard will be appreciated.
