You should go for oil change regardless of the KMs, if you completed the time duration you qualify for free inspection and oil change is also due after time, even if you dont drive your car at all, you should change lube oil with respect to time, means which ever comes first. And there is also Gear Oil change on first inspection, take a good Gear Oil and Lube with you or take advise from dealership for the best grade oil.
