^^ WHY did you touch that screw - its locked into place for a reason. its the calibration point for the throttle blade and TPS. if you fiddle with it too much you will end up with a twisted throttle blade and shaft in the throttle body. The throttle blade is set from the factory for proper MAP signal, TPS and throttle plate angle taking into consideration of engine temperature too.
There is actually no idle adjustment screw on this engine (if you look at the original cars bonnet sticker that had this engine it also says no idle speed adjustment)
Ive seen all CNG shops in Karachi fiddle with that screw - and I literally want to shoot them.
A proper idle speed adjustment screw is the brass bleed screw that you see on older Toyota throttles
