@mtn.ubl.ali
on ATS side intall proper Amperage Circuit Breaker, It will trip if more load is present will save your long run to the generator for setting its Circuit Breaker. If you have
2.5 KVA Generator = install 10 AMP
3.0 KVA = 13 AMP
4.0 KVA = 18 AMP
5.0 KVA = 22 AMPS
6.5 KVA = 29 AMPs
These circuit breakers are not available from common electric store, If you live in Lahore then on KHARAK Stop you can get from ALI BILLA Electric Store. Its one of the Lahore's Advance part store.
In Islamabad I believe there must be some one in SULTAN ka KHU, In common store you will find only 5 AMPS, 10 AMPS , 20 AMPS , 32 AMPS , 63 AMPS and 100 Amps circuit breakers. But from a Specialty Store you can find all the amps range.
