agoodfriend, a_n_memon88, hanimughal,moizirfan
it was a mess, when i got engine overhauled last year mechanic forgot to connect oil sensor to generator, which i also did not noticed at that time, since few days i had the problem of oil decreasing which was quite significant, i never added oil before and was adding up since last few days, yesterday i drained old oil and found out about oil sensor and that there was minimal volume of oil in the chamber, i added up new oil and started and since then it has started giving heavy smoke at the start of generator. then smoke disappears, i think ring has gone, but can there be some other thing as well.
i want ask senior members if i plan to change ring, how would i know that piston is also worn out or else can be used, if i am using same piston (if piston being good) what size of ring should i use, shall i take piston to shop and ask for ring showing him the piston.
secondly is it good to take out only generator engine from flywheel side (would be more easier), rather dismantling it from rotor and field side.
thirdly how would i connect oil sensor, there are only 3 wires coming out and all are connected, i can not find any point to connect oil sensor wire.
urgent reply is needed as i want to get it done before eid.
regards
