For few days my generator would just stall after few seconds of starting. Would run fine on cranking again.
But today it refused too keep running. Would stall again and again.
When i started to check out the problem it got worse.
Changed the plug. Run for few minutes this time but again stalled. Adjusted the tappets also but problem remained.
Now it hesitates to speed up and misfires and back fires and randomly jerks and stalls... Finally it did some firing through exhaust...
Cam its cam for valves be the issue? As the ignition is happening at intake and st exhaust randomly.
