nope thats not a good idea,,,,,,,,,,,,,this is just a kind of dummy carb,,,,,,,,check the pic which i attach,,,,,,,,,,,,,the one is send you works 100% same as this one,,,,,,,,,,,such carb comes in early days when carb with built in gas kits are not availabe ,,,,,,,,,,,,,,green power generators comes withs such carbs and with chinese factory fitted gas kit which you can see in this yellow generator and i also attach its pic,,,,,,,,,,,,,,that gas kit works much batter than our local made gas kits and it need no mod,,,,,,,,,,,later this setup is replaced with a smaller and more cheaper carb with built in gas kit,,,,,,,,,,,,,,,,,
