JLT is working fine and these days its in use for atleast 10 hours a day ,,,,,,,,,,,,,i have seen this clip ,,,,,,,,,,,,,its shows 5 to 6 amp on clamp meter ,,,,,,,,,,means around 1000 to 1200 watts,,,,,,,,,,,,,,thats the rated power input of that AC ,,,,,,,,,,,,,,and the rated power of generator is 2500 Watts , means he can put more load on generator once he switches on the AC first ,,,,,,,,,,,,,,,the full load current of AC is may be around 1500 to 1600 watts ( it may be written on its label ) ,,,,,,,,,,,,,,and the full load mean peak power of generator is around 2800 Watts,,,,,,,,,,,,in theory this generator must runs this AC and i think is it doing so,,,,,,,,,,,,,,,during starting AC runs on its max load as both the starting and running winding of compressor works at the same time ,,,,,,,,,but it happens only for first few seconds of starting and the starting winding of compressor cuts off once the comp motor reaches its working RPM ,,,,,,,,,,,,
i havent try my 1 ton AC on 2.5 Kw generator but i am sure it can support it,,,,,,,,,,,,,
