I have the following grease at my disposal. Which out of the two would be better suited to lubricate the propeller shaft spider joints of a Hilux, Fortuner, LandCruiser?
Mobilith SHC 220 red-lithium complex synthetic grease
From the manufacturer:
Mobilith SHC 220 is a multi-purpose, NLGI 2 extreme pressure red-lithium grease recommended for heavy-duty automotive and industrial applications. It uses an ISO VG 220 synthetic base fluid. Mobilith SHC 220 has a recommended operating temperature range of -40 C* to 150 C.
Mobil XHP 222 blue-lithium complex grease
Mobilgrease XHP 222 is recommended by ExxonMobil for industrial and marine applications, chassis components and farm equipment. Its sticky formulation stays in applications longer.
The Mobilith SHC 220 has a synthetic base oil and a dropping point of 265C. While the XHP 222 is a mineral oil-based grease with a dropping point of 280C. Both seem very good to me for propeller shaft u-joint lubrication.
However, if we were to choose, which would be more preferable?
For the Slip-joints, I plan to use Mobil XHP 462 Lithium-Moly (3%) grease.
@Xulfiqar
