Fuel injectors on 1.3 and 1.5 are same on nz series
Now on the other hand on single line fuel system there is no such PWM control fuel pump which variate's the pump. The pump on single line fuel system operates at same pace where as there is a built in fuel pressure regulator in the filter housing assembly which maintains the 50 -60 psi pressure in the rail.
If you disconnect the pressure regulator and hook up the pump directly on the single lime yes it would die earlier.
Study it
