Ok, well couple of time i have noticed that when car is heat up then coolant is coming out from the radiator and the resort bottle level goes up to.
Last week mechanic checks the Thermostat and said its ok no issue in that, he cleans the throttle body with foam sprayer and remove the air from the radiator.
According to him something is wrong with radiator grill its need service so air can pass through and he also said might be the fan is issue but he didn't said anything about water body so will check that part to.
So now i think first i need to ask him to check the water body pump, then check thermostat again after this check the radiator pipes any leakage or blockage if nothing found then will asked him to do a radiator service and will see if the issue again showed up then go for the radiator change, does it make sense?
Please suggest.
