Now i doubt it may be is a gasket problem... are these images above are suggesting anything?
check the above image as well
Hello All
Car is still heating what can be the other possible reason?
radiator,gasket eveything chanheck and is Ok..
wat else can be the reason?
Raditor wala by mistake changed direction of radiator mouth.. can this cause any problem
check the clutch cable it might be hitting the fan wires and use coolant
check post 81 why there is oil around these bolts is it smething normal
How do you know that ur car is overheating??is water boiling in the reservoir??
temparture guage is going above midle .. no water is not boiling in reservoir bottle
head packing cover is leak nothing to do with heating and what i wrote as it was case with our santronow its solved car use to heat up after 15 mins and we tried every thing but main culprit was the clutch cable hitting the rad fans wire and short circuiting them
remove t-stat,direct out the radi fan,and then check.the needle should move only about 20% without ac.if the needle is still moving above,then i think ur temp. guage is faulty.if it works then u have faulty thermoswitch.
and also check the fan speed
how removing T stat will solve the issue? when dere is no issue in T stat... auto to direct fan wat diferenCe it can make that car will take 20,30 min more in heating up..
how can i check its speed?
t stat vlve can stuck close.it is build to open up when the temp is 71c and fully open at 81c.thermo switch kicks in at 91c.it can also be faulty.i am 90% sure that ur temp guage is faulty.coz when car overheats water starts boiling in the reservoir.
T stat is OK.. in start only top hose pipe is hote later on lower hose will heat up againt that means T vale has opened..
where is thermo switch?
may be there is issue in connection of radiator and its reservior bottle that it is not tranfering pressure to it? is it posble?
Thermo switch is a device that switches on and off the radi fan.dnt know the exact location in santro.temp guage shows the temp of the engine and is connected to the engine.
when the car is cold after a drive,is the radi empty of full?
almost full
