Hi fellas I am facing from a very severe problem my ride (2007) keeps heating up in traffic jams (without AC) and with AC its perfectly fine When i got her she was having WATER in radiator, after facing this issue i got 5 bottles of coolant from HONDA and started scrolling through form... Hopefully i have a friend and he is really really good at cars (maintaining reborn since 2008)... He said Yr pani jaldi boil ho jata ha or steam ban jata ha... Tujay latey sath hi coolant dalwana chie tha , i said Yra kall dalu ga pani drain kar ka and he told me that first get the radiator serviced completely. Well delayed the program and carried on water... After again getting heat up problem (While going to High Lands) i was really fed up -_-... My heart was saying U are getting her F****D up, do some thing... Well today i got up from my comfort zone and went to my local RADIATOR WALAYS... Only 1 was sincere with his job and gave me a walk-through the whole process... 1. Opening Radiator, 2. Using some kind of BLADE cleaning the side walls, 3. Acid clean and done... Whole process will take 1.5 to 2 hrs and mazdoori will be 600... i said OK... and went to an electioneer (The best in whole TAXILA) he said Sir g saaf karwa lay radiator or coolant bi dalwa le, garmian ha is lie pankha bi direct karwa lay or thermostat bi remove karwa lay, i said making the fan direct and removing T will be an temporary solution... i said in SUMMER i always use AC and while AC is on there is be no heat up issue in any kind of traffic jam. he said agay app ki marzi, Then i said yr is ki koi relay ka issue na ho he said nhi ho sakta and than i said AC chalao to 1 fan on hota ha means 1 trah ka direct keh lo jab sardian ae gi or ma heater chalao ga to phr wapis wohi hall ho ga heating up he siad nhi ho ga bhai after radiator ki service Any help will be appreciated... What can cause this problem? NOTE: Without jams car doesn't heat up even on long routed or on hard foot...
Sorry for any kinds of GRAMMAR MISTAKES
Bhai mujhy 100% fan ka issue lag raha ha, only fan direct kr wa kr chk kr layen, or thermostat valve new dalwa lo being on safer side..
Paani waghera kum tou nahi hota radiator ka?
Shahid thermostat rust ke waja say stuck ho raha ho... Or kia fan mid temp ma on hota ha
Yr sardio ma kia karu ga? Coz sardio ma bi heat up hota haThermostat to kharab ho ga to phr na...
Jab gari heat up hoti ha to pani kam hota ha waisay normal rehta ha... Normal routines pr 50 ml tak kam hota ha... Ab pani ha yr itna to evaporate ho ga na...
Fan ka ma confirm karta hu... Agr rust ki waja sa ho rha ha to kia karu? Kitnay ka thermostat a jae ga?
Brother you need to check each and every hose in your car. To do that, after driving your car for 15-20 minutes, open the bonnet and check for any leaks. If water is dripping from any of the hose, get it replaced asap. Mery sath yehi masla tha, gaari heatup hoti thi and paani kum hojata tha, Sub kuch karwa kar dekh liya and end mai eik hose thi jo leak thi. 20 rupay k badalwayi and ab tak theek hai Allah ka shuker. First of all check for leaks, and don't remove the Thermostat or get your fan direct at any cost, find a proper solution.
Where should i search for leaks?????
Attention please, some time after heating up there is some kind of boiling sound coming from the radiator
And that's how you know something is leaking. Boiling sound comes when hot water dissipate from the hose. All you need to do is, and do it yourself, gaari ko 15-20 min chala kar and roshni mai sab pipes waghera dekhain k kisi mai sy paani leak tou nahi horaha. Acha tareeqa yeh hai k eik dafa coolat dalwa lo, kyun k coolant ka color orange ya green hota hai tou it would be easy to recognize. Coolant dalwa kar, gaari ko ghar lakar, park kar k, leaks check karain, most probably leak wahan sy horaha hoga jahan sy boiling ki awaz arahi hogi
Sai but agr temp normal rhay to koi boiling ki awaz nhi ati
Allah ka naam ly kr fan direct krwao, q ky ac fan ko power dy ny ky lia alag reley hoti ha, jis ko ac ecu control krta ha, agr ac ka head pressure bardash kr rahi ha then car engine totally fine
zara pls detail ma samjhaie
Yr jb ac on krty ho tb heat up nai hoti?
g ac ka sath nhi hoti jesi marzi condition ho, jitna marzi floor karo jitna ganda or lamba traffic jam ho nhi hoti
Bhai ap ka auto fan ka system kharab ha, mgr jb ac condencer ky lia fan on krta tb radiator ko air milti ha tb thanda rahta ha.. . Connection thek kr wa lo ya direct battrry ky sath kr ky chk kr lo.. .
yr is ka direct karwanay ka ilawa koi hal?? or yh kaisay pata lagay ga ka waqai hi auto fan masla kar rha ha??
Ma testing ky lia direct ka kha raha hu, agr yahe msla huwa phr connection thk kr wa lana
Aik wire lagy ge
