Bought this Honda City in December last year, last week was the first time I took it on long drive out of Isb - Rwp area.
Before going, I got the oil changed (shell 10W 40), plugs changed, tappets adjusted, coils replaced, fan belt changed and other general tuning.
Now, I got on motorway around 4pm and AC was on since I started my journey. When I was somewhere between Chakri and Kalarkahar, the hot temp light started blinking. Luckily I noticed it right away, turned the AC off and parked the car on the side. the water in reservoir bottle was boiling, so I poured water on radiator and added poured some water in the bottle and closed it.
Without AC and with speed under 70, I reached kalarkahar, where I parked the car, turned it off, poured water on radiator, let it cool for 5 min. Then opened the radiator cap, the water was low, added around half a liter of water to fill it then closed it and started my journey again. Luckily I had the OBDII adapter installed in the car so I started monitoring my temperature. Without AC, with speed till 80 the temp was reaching 100-105C
On my journey till Sahiwal, the max temp I saw was 111C. Throughout the journey I stopped where ever I could to check water in reservoir bottle and pour some water on radiator to cool it down.
Got it checked in Sahiwal, motor on one of the fans was stuck causing the increase in temp.
Now, with AC and speed till 80-85km the temp stays under 98C
Problem is if I go above 90 even without AC the temps starts rising and within minutes the temp reaches 107 and that's where I remove my foot from the accelerator.
The main issue was crossing the hilly area before Kalarkahar on my way back. The car wouldn't give any response, even in 2nd gear I was barely getting any speed, the temp rose upto 113C (around 9pm last night).
In Sahiwal, the mechanic checked the head gas kit with those tests like opening the radiator cap with running engine and pressing accelerator, the water didn't come out at high speed, there were no bubbles or oil in water. He told my that my gas kit is okay.
Sorry for the big story. Now I don't understand where the problem lies, is it the cooling system or the engine is weak?
No matter how hard I press the car won't go above 110, even on motorway. But, never felt lack of power locally, in Isb, the response is good, it is not reducing oil, no smoke of any kind, AC cooling is awesome, fuel average is amazing. While getting the car tuned the mechanic said "crank ki halki si awaz hai engine ma"
So need expert opninion on where the problem lies as I don't want to take it to a mechanic who'll just open up the whole engine to make more money for himself.
Sorry for the long story
