I have been a fan of the 1.5L NEO ever since I drove one a few years back. The car was running on CNG and I was quite impressed by its performance. So when I got the chance, I replaced my 1.3L one with a 1.5L NEO.
When I bought the car it had CNG in it and was meant to be a daily runner and for the past year and a half it has been running as one with minor repairs. However, now that we have a second car at home, I believed it was time to restore some of its former glory.
I set a couple of rules for myself before taking up the challenge. First, this is not going to be a ground-up sort of restoration rather a salvage project. Second, the expenditure will be kept at a minimum (though essentials will not be compromised).
The car requires work in all areas including mechanical, body and interior.
First things first, here is a list of stuff already completed on the car:
1. Replaced 4 x coil springs and shock absorbers.
2. Replaced 2 x axles
3. Replaced all bushes and balljoints
4. Replaced track rods
5. Replaced 2 x front disk brakes and pads
6. Replaced 2 x rear drums and shoes.
7. Replaced brake booster
8. Serviced braking system.
9. TO BE DONE - Power steering pump replacement.
Engine
1. Removed CNG kit
2. Replaced all oil seals
3. Had throttle body and injectors serviced
4. Replaced injector seals.
5. Replaced MAF sensors.
6. Engine timing adjustment after CNG removal.
7. Replaced fuel filter and fuel lines.
8. TO BE DONE - Engine mountings replacement.
9. TO BE DONE - Engine retuning / timing
10. TO BE DONE - Any other engine related work.
Though interior and bodywork are least priority, I wanted to list a few items that I need PW member's help with.
1. Replace steering wheel with 2001 model
2. Replace instrument binacle
3. Replace air vents and broken grills.
4. Complete interior cleaning.
5. Door cars proper fitting.
Body (TO BE DONE)
1. Repair and repaint front and rear bumber
2. Repair and repaint hood and both front fendors
3. Rubbing and other stuff.
Need Help With
1. Original emblems (like the ones shown in the picture below).
- Interior grills, AC vents and steering wheel (like the ones shown below).
I am not sure if this thread will be followed by many, but hopefully it will serve as a project log for me and I will continue posting stuff that might help others. I will also post pictures of the car tomorrow.
