I believe that your car AC lower discharge hose is leaked from somewhere, the gas leakage process is very very slow, so these can be the symptoms and i would recommend you to visit HONDA DEALERSHIP and make an arrogant behavior that you would not leave the place until your problem is solved by the same day. OR from which city do you belong to?? if you can manage to travel LAHORE and approach to HONDA GATEWAY; then that is a best place to get your problem solved.
There are 4 possibilities, the first one I have discussed in above paragraph whereas;
2- Change the valve TXV, if found faulty
3- Change the thermostat, if found faulty
4- Faulty Evaporator temperature sensor, if found faulty.
