[quote="arsalaanali89, post:1188, topic:184235, full:true"]
ahan,,, i am posting a link to purchase it then, this link is to genuine Honda Fuel filter, this website also has chinese filter which costs 500 rupees.
by the way this website has almost everything of CF4 available and prices are really competitive too.
http://www.smmotors.org/fuel-filter-genuine-cf1
VTI and most probably EXI as well have two filter assemblies. one u can find near the fuel tank on the underside of the vehicle on left side. It's a bottle type unit, n u can source it for around ~800. Inside the fuel tank, there's a fuel pump with its restraining filter. u can change the restraining filter for around ~100. It is strongly advisable that one changes both the filters. Pertinent to mention here that when u check for the filters do check the fuel pump as well. recommended pressure output of the fuel pump is 42-48 psi at 2000 rpm. if the fuel pump pressure output is less, u need to change the pump. if the fuel pump has gone bad it will result in reduced mileage and decreased engine performance of the vehicle
[/quote]
So my investigation was right
and this clears all the confusion.
Please suggest how to measure fuel pressure?
