bump!
Awesome stuff man, reasonable price aswell.
thanks! It surely is awsome.till the time u actually dnt feel it in your hands u cnt really judge how the leather feel is plus the utility of the buttons especially the audio controls and CRUISE control(coming sooon....!)
hello broi might be interested in buying this but i want to install it in my 99 civiccan u confirm me if it will fit.At this time i m using a four spoke steering with the clock spring mechanism.if u could help that will be grt
Check post #13 on 1st page for ur answer
bump
bro can u measure internal diameter of d bore (jahan per nut tight hota hai)on steering wheel will be waiting for ur reply
i measured it.its something like 1.6~1.7 cms
^the nut is even smaller as this is the outer part that fits in.if this is same.then the central nut will definitely fit.@all_blacx how many pins does ur clockspring have? U will need to replace it with the civic clockspring or cut the audio wires n will have to solder them directly(not recommended) to ur existing clockspring if it has more than two pinouts
What about the airbag ??
^ the stock airbag/horn cover will fit into the airbag space. Airbag is not incl. Just airbag will cost u around 19-20k alone.
priced is slightly negotiable n not fixed.
Bro can it fit in vti manual?? I mean considering it doesn't have air bags and also that it has manual tranny... Response awaited...Thanks!!
Yes you can but then the price would be around 5K-6K more as you'll have to change the clockspring.
yep it can. N as istafa said u will need to change the clockspring to get audio controls to work.also the stereo has to be supporting remote/audio controls. Which stereo are u using?
brand new oriel clockspring can be arranged at RS 4900. Price at honda is around 9-10k. Got some from a wholeseller in UK for few pakwheelers
It's the same kenwood audio that comes with vti... Would it support steering controls?
Clockspring? Is it something related to electrical circuitry of car?
ive given a detailed explanation /description of the working of clockspring at the fol linkwww.pakwheels.com/forums/electrical-wiring-battery-lights/177234-cygnus-2005-steering-wheel-buttons-not-working#post3028434
