Please tell me when do we need to change the followings according to the manual:1) Engine Air Filter2) Engine Oil Filter3) Cabin Air Filter4) Automatic Transmission Filter5) Fuel Filter.
I dont have manual & need to know what Honda suggests manual asap.Regards.
1) Engine Air Filter Recommended on 10k but if very dusty better to change early, i change on 8k2) Engine Oil Filter on every 10k (second oil change)3) Cabin Air Filter Recommended on 20k but if very dusty do it early, i change on 20k4) Automatic Transmission Filter No filter in it5) Fuel Filter. Not changed yet on 80k
Aoa Brothers,Yokohama advan db has been discontinued , Adavan 2 is coming on next year, Imported Yokohama blue earth ES32 available, any one used it ? what are the options now, continental available but smuggled one.
Thank you & are you sure about automatic transmission filter? As far as I know, there is a filter.
it has an in line atf filter part no, 25430-plr-003
& it needs to replaced at how many kms?
I checked with an assembler in Honda factory, according to him this is an integrated filter which is a steel mesh only and cant be replaced. further no externally replaceable filter in 9th gen prosmatec tranny.
Where is automatic transmission filter located
good to know paise bach gaye
What does the manual say about fuel filter replacement as my car is driven more than 70,000 kms & Honda mechanic suggested changing it at 80,000 kms?
Aoa. Pakwheelers I have bought honda city 2011 130k driven. Engine is in perfect condition. Kindly suggest mei which grade of oil should i use?
around 60-70k kms is a safe bet
sir check the part in line filter ata hai in this civicaap confirm karna maybe you are talking about the cvt trannyus mein filter nahi hota external
10w-30
Total 5w30 from Honda Center Peshawar Road or Mobil 1 0w40
it is located on a line coming from the trannyits under the air box at the back of the engineyou ll need to look for it to find itcheck a youtube video to know the exact location of it
Sir what about liquimoly 10w40?
Sir what is your review about liquimoly 10w40?
would be a lovely choice......go for itlm makes some superb oils
It is also good, but you should also check on LiquiMoly's website about what they recommend for the car.Most people use 5w30 (including me) and it's also good.Do keep track of the change intervals as liquimoly tends to last longer.
