What about the vehicle stability and grip after change in tyre dimensions. Have you experienced this change , and how much the difference u feel after this change. Thanks
There won't be any significant change to neither the vehicle's suspension geometry nor stability. Lower tire pressure will increase the contact patch which will improve high speed cornering, but will increase rolling resistance and therefore decrease fuel economy by about 5%.I'm satisfied by lowering the tire pressures only.
should i refill my brake oil or not bcz my brake oil is almost at its low level ? mechanic says its normal you should not worry .. can somebody explain me on this ?
When did you replace it? If not then do a flush, otherwise refil with fresh fluid.
I didnt . Mechanic says brake pads consume oil so not to worry but it doesnt make any sense . Should i refill it ?
Always refill your brake fluid to it's optimum level. It's a hydraulic system and it won't work without it's fluid.
When did you last change your disc pads?
Minor variation is negligible. Refill & you will be good to go. If the problem persists then you have a vacuum leak.
Its just 45k driven so didnt change yet . Just curious why its level went down
Oh i will get it checked
when brake pads wear its level gets down, its normal. however in any case it shouldnt be dropped below the minimum mark (level).
okay thankyou for the reply now i will refill it
AOA,What are the best tyres for civic, comfort, grip, durability , Please reply.
Continental Premium Contact 5. I have them on my 2007 Civic hybrid and it grips really well.I'm using Goodyear GT hybrid tires on my 2013 Civic VTI Oriel and they have slightly more road noise, but are still really good.
What about Michlin energy saver plus in comparison with continental
Continental CPC5 VS CC6 Please mention which one is better ?
I haven't used CC6, so can't say.
CPC5 is touring oriented which kind of fall is premium comfort category. Cc series is the most economical one which conti offers. I say go for cpc
Well.Thanks for reply. What you think Continental is better than Michelin ??
cpc 5 conti here as well. Superb tyre
