Its ok, please take your time on this as and when your schedule allows.
I feared you had gone to an electrician for the '10 minute job'.
In your first post you said your car has an original horn which has one wire going to it and earth is given to the body of the car.
Waht I undertand from this is its a one terminal horn and the earth is taken up by the bracket attaching the horn to the body.
For most if not all electrical components in an automobile, ground is taken from the cars body. If you have a keen eye you might have noticed the negative terminal in a car being attached to the body.
Does your original horn have a relay???
Tons of pics here wont hurt anyone. It would be good if you post as many pics as possible both of the old setup and the new unit with the relay.
Regards
