i have a civic vti 2000 , d15b swaped , mods only air intake going for headers n 2.25" plumbing free flow, tyre size is 195/70 r14 singa radial in fine condition i know they r hard tyres will change but after some time , rims r stock as of vti that enkei ones
yea wheel spinns too much even till third gear rev is good but after 3rd n 4th it is slow ,so it seems that cluth n pressure plate r fine
ride height is stock n nothing is wornout wheels r aligned but not balanced
1st gear is fast bt then its seems slow on 2nd n third n in 4th its too slow going from 4700 to 6500 is very slow toping till 70 is quick bt after that respons is bad some type of lag r what ...........
what does i do for fuelling it seems pressure is droped after 3rd shift
so walbro isnt a good option ?? i thing it will give good pressure n the over fuel will come back to tank thru return valve
engine compression seems good , what should i do
can i go to 200whp without turbo
what about stage 2 cam shaft ? n ported n polished internals ? some after market performance valve springs ?
[I]Are you having cng? and venture?
are you sure your vtec is working? what is the ecu code? are you having any check engine light? and smoke from exhaust? rich fuel fumes?
[/I]
