There had been a lot of confusion about the hybrids/ Plug-in Hybrids and Electric vehicles here on this forum. I have collected some information to share so that we can increase our knowledge base. I am not the writer of this information. I have collected it from United States Dept of Energy for our learning. In the end of the article you can go to the source link.
Before we go in depth, I would encourage you to click on this link and watch the animation. How the technology work while at starting , cruising, Passing , Braking and at Stopped positions. Please navigate on top menu of the animation window between Hybrid ,Full Hybrid and Start/stop . Hybrid Vehicles
http://www.afdc.energy.gov/fueleconomy/animations/hybrids/swfs/hybridframe.html
Hybrid Electric Vehicles
Hybrid electric vehicles (HEVs) are powered by an internal combustion engine or other propulsion source that can be run on conventional or alternative fuel and an electric motor that uses energy stored in a battery. HEVs combine the benefits of high fuel economy and low emissions with the power and range of conventional vehicles. A wide variety of hybrid electric vehicles is currently available. Although HEVs are often more expensive than similar conventional vehicles, some cost may be recovered through fuel savings or state incentives.
Help from an Electric Motor
Hybrid electric vehicles are powered by an internal combustion engine and an electric motor, which uses energy stored in batteries. The extra power provided by the electric motor allows for a smaller engine. Additionally, the battery can power auxiliary loads like sound systems and headlights and reduce engine idling when stopped. Together, these features result in better fuel economy without sacrificing performance.
Regenerative Braking
A hybrid electric vehicle cannot plug into off-board sources of electricity to charge the battery. Instead, the vehicle uses regenerative braking and the internal combustion engine to charge. The vehicle captures energy normally lost during braking by using the electric motor as a generator and storing the captured energy in the battery. The energy from the battery provides extra power during acceleration.
View an animation showing how HEVs work Hybrid Vehicles . Download Flash Player or view the text version here Hybrid: Overview
Fuel-Efficient System Design
HEVs can be either mild or full hybrids, and full hybrids can be designed in series or parallel configurations.
Mild hybrids also called micro hybrids use a battery and electric motor to help power the vehicle and can allow the engine to shut off when the vehicle stops (such as at traffic lights or in stop-and-go traffic), further improving fuel economy. Mild hybrid systems cannot power the vehicle using electricity alone. These vehicles generally cost less than full hybrids but provide less substantial fuel economy benefits than full hybrids.
Full hybrids have more powerful electric motors and larger batteries, which can drive the vehicle on just electric power for short distances and at low speeds. These systems cost more than mild hybrids but provide better fuel economy benefits.
There are different ways to combine the power from the electric motor and the engine. Parallel hybrids?the most common HEV design?connect the engine and the electric motor to the wheels through mechanical coupling. Both the electric motor and the internal combustion engine drive the wheels directly. Series hybrids, use only the electric motor to drive the wheels, are sometimes found in plug-in hybrid electric vehicles.
Plug-In Hybrid Electric Vehicles
Plug-in hybrid electric vehicles (PHEVs) use batteries to power an electric motor and use another fuel, such as gasoline or diesel, to power an internal combustion engine or other propulsion source. Using electricity from the grid to run the vehicle some or all of the time reduces operating costs and petroleum consumption, relative to conventional vehicles. PHEVs might also produce lower levels of emissions, depending on the electricity source.
Heavy-duty vehicles can be converted to PHEVs and a few light-duty PHEVs are commercially available. Although PHEVs are generally be more expensive than similar conventional and hybrid vehicles, some cost can be recovered through fuel savings, a federal tax credit, or state incentives.
Powered by Electric Motor and Engine:
Plug-in hybrid electric vehicles have an internal combustion engine or other propulsion source and an electric motor, which uses energy stored in batteries. PHEVs generally have larger battery packs than hybrid electric vehicles do. This makes it possible to drive moderate distances using just electricity (about 10 to 40-plus miles in current models), commonly referred to as the "all-electric range" of the vehicle.
During urban driving, most of a PHEV's power comes from stored electricity if the battery is charged. For example, a light-duty PHEV driver might drive to and from work on all-electric power, plug in the vehicle to charge it at night, and be ready for another all-electric commute the next day. The internal combustion engine powers the vehicle when the battery is mostly depleted, during rapid acceleration, or when intensive heating or air conditioning is required Some heavy-duty PHEVs work the opposite way, with the internal combustion engine used for driving to and from a job site and electricity used to power the vehicle's equipment or control the cab's climate while at the job site.
Fueling and Driving Options:
Plug-in hybrid electric vehicle batteries can be charged by an outside electric power source, by the internal combustion engine, or through regenerative braking. During braking, the electric motor acts as a generator, using the energy to charge the battery. Learn more about charging PHEVs.
PHEV fuel consumption depends on the distance driven between battery charges. For example, if the vehicle is never plugged in to charge, fuel economy will be about the same as a similarly sized hybrid electric vehicle. If the vehicle is driven a shorter distance than its all-electric range and plugged in to charge between trips, it may be possible to use only electric power.
Fuel-Efficient System Design:
Beyond battery storage and motor power, there are various ways to combine the power from the electric motor and the engine. The two main configurations are parallel and series. Some PHEVs use transmissions that allow them to operate in either parallel or series configurations, switching between the two based on the drive profile?this is called "blended mode" or "mixed mode."
Parallel hybrid operation connects the engine and the electric motor to the wheels through mechanical coupling. Both the electric motor and the engine can drive the wheels directly.
Series plug-in hybrids use only the electric motor to drive the wheels. The internal combustion engine is used to generate electricity for the motor. General Motors (GM) uses a slightly modified version of this design in the Chevy Volt. GM refers to this design as an extended range electric vehicle (EREV). The electric motor drives the wheels almost all of the time, but the vehicle can switch to work like a parallel hybrid at highway speeds when the battery is depleted.
All-Electric Vehicles
All-electric vehicles (EVs) use a battery to store the electrical energy that powers the motor. EVs are sometimes referred to as battery electric vehicles (BEVs). EV batteries are charged by plugging the vehicle into an electric power source. Although most U.S. electricity production contributes to air pollution, the U.S. Environmental Protection Agency categorizes all-electric vehicles as zero-emission vehicles because they produce no direct exhaust or emissions. Because EVs use no other fuel, widespread use of these vehicles could dramatically reduce petroleum consumption.
Both heavy-duty and light-duty EVs are commercially available. EVs are typically more expensive than similar conventional and hybrid vehicles, some cost can be recovered through fuel savings, a federal tax credit, or state incentives.
Driving Range:
Currently available EVs have a shorter range per charge than most conventional vehicles have per tank of gas. EV manufacturers typically target a range of 100 miles on a fully charged battery. According to the U.S. Department of Transportation Federal Highway Administration, 100 miles is sufficient for more than 90% of all household vehicle trips in the United States. For longer trips, it is necessary to charge the vehicle or swap the battery en route.
The efficiency and driving range of EVs varies substantially based on driving conditions and driving habits. Extreme outside temperatures tend to reduce range, because more energy must be used to heat or cool the cabin. High driving speeds reduce range because of the energy required to overcome increased drag. Compared with gradual acceleration, rapid acceleration reduces range. Hauling heavy loads or driving up significant inclines also reduces range
Source: Alternative Fuels Data Center: Hybrid and Plug-In Electric Vehicles
MPGe Explanation:
Since an alternatively fueled engine can't be measured by liquid gallons of gasoline, it is measured by the number of miles it can go using the same energy content as a gallon of gas. One gallon of gas produces 115,000 BTUs. As a measure of energy output, 115,000 BTUs is equal to the electrical output of 33.7 kilowatts per hour. The EPA calculates that 33.7 kilowatt-hours (33,705 watts) of electricity is equivalent to one gallon of gas. So when an electric car uses 33.7 kWh of electricity, it is by comparison using the energy equivalent of a gallon of gas. If an electric car uses 85kWh, like the Tesla Model S Performance, it is not a gas guzzler but an electron eater, for lack of better alliteration. That means the Tesla with that high-end battery pack uses the equivalent of about 2.5 gallons of gas per 100 miles. The Nissan Leaf, with its 29 kWh, uses the equivalent of less than one gallon (33.7 kWh) of gas per 100 miles. That's why it gets a combined EPA rating of 115 MPGe.
Beneath the huge MPG or MPGe number is a more accurate comparison measuring how many kilowatt hours per 100 miles and how many gallons per 100 miles.
http://cars.chicagotribune.com/fuel-efficient/news/chi-what-are-mpg-and-mpge-20130506
