https://www.thecarconnection.com/news/1132209_hyundai-issues-3-recalls-for-elantra-kona-santa-fe-sport
2019-2021 Hyundai Kona and Veloster
2019-2020 Hyundai Elantra
The second recall also involves a higher risk of fire and is an expansion of a previous recall. This one is for newer Hyundai models. The 2019-2021 Hyundai Kona small SUV and Veloster compact car, as well as the 2019-2020 Elantra compact, join other Hyundai and Kia models recalled with a 2.0-liter Nu engine that is an inline-4 making 147 hp.
The recall covers 125,840 models for a hardened piston oil ring that can scuff the cylinder bore and eventually seize a connecting rod bearing, potentially causing the seized rod to puncture the engine block, leak oil, and ignite a fire.
Owners of an affected vehicle might notice engine knock, reduced or hesitant power, the "Check Engine" or oil pressure lights might illuminate in the cluster, and it might smell like smoke or something burning.
Hyundai will inspect the engine and fix it if damage is found, and the service center will make a software update to monitor unusual engine vibrations. There will be no cost to owners and Hyundai will reimburse owners who paid for work done to fix the issue.
2021 Hyundai Elantra
The redesigned 2021 Elantra is also being recalled for welding issues with the front seat backs. The affected vehicle population spanned only two weeks in Hyundai's Alabama plant, so only 1,464 Elantras are affected. Owners should have the front seat back frame inspected and repaired free of charge.
To check on the status of your vehicle, enter your VIN at Hyundai's recall site or call Hyundai customer service at 1-855-371-9460.
