PTCL complaint registration people at 1218, know your problem well , But they always try to deceive you in technicalities like
Rosette
Spiltter
PAIRS
Port refresh
Noise Margins
attenuation
They are trained not to admit their own problem, 99.99% problem is always at their side, But they always put ball it in your court.
If joints are properly made , joints live for always, These joints if done properly according to books have nothing in attenuation. This is my personal experience, They might cause resistance when very high voltage are applied but in normal stuff its not the problem.
SNR Margin (dB): 9.0 35.3
Attenuation (dB): 51.0 35.1
Output Power (dBm): 16.3 12.1
Attainable Rate (Kbps): 1212 987
Rate (Kbps): 509 125
Look the injustice they are doing with me, My attainable speed 1212 Kbps but they are down grade me on 509 Kbps. I am paying for 1MB.
Output Power (dBm): 16.3 12.1 if you look at this field, this is what exchange has to set for proper speed, It the amount of the power which is need to throw signal away, if you are away it should be higher like 19 - 20 even I have seen 25.
PTCL is so bad
