need all of your collaborative input in this.
2 TON gree inverter. when I attach the pressure hose and turn the ac on. after the reading on gauge stabilizes it comes to 100 PSI when the A.C. is taking full amps. Once temperature is reached and amps start to reduce, the pressure reading on gauge is 130 and goes upto 140 as amps reduce.
However my other 1.5ton gree inverter shows a running gauge pressure of 120PSI whether it is at full amps or lesser amps. (this a.c.s compressor was replaced and before, it too would show 100PSI at full amps and then pressure would go up when amps would come down.
So basically, my LG inverter always shows 120-130 psi pressure and im quite amazed that GREE 2 ton goes to 100psi when a.c. is switched on and it is running on full amps. When i try to fill gas at 100psi to bring it up to 120 it takes the gas but will not increase the reading until amps go down.
Any advice on whats going on?
