My feedback from using gree 1.5ton gs18lith11m..
Pros;
Cooling is great! My room is quite big and a 2ton unit would be recommended but i went for the 1.5ton option.. iv put the temp at 26 and within half n hour i can easily feel the difference..the room remains cold for an hour or two after switching it off.. it does cool quickly but i was using a 2ton window ac, i obviously cant compare the cooling between the two.
Wifi option is of great use.. you can control everything from your mobile. Frm vent positions, fan speed, light, temp to almost every option you have on the unit. You can easily switch on ur ac remotely from anywhere!
The outer unit is huge! Its almost the same size of mistsubishis 2ton outer unit i have.. If there was anything i was sold on..it was the outer unit! If i compare it to a normal 1.5ton gree unit..its almost double the size. Waisay, are bigger outer units for inverter acs beneficial or is it something which ive made up in my head?
You can set the vent movement left/right and up/down from the remote.. i dont know about previous units..but the last gree ac i got, i had to manualy set the vents where i wanted. You have numerous positions to set the vent movements to..
Cons;
The price! I got 3 units for 74k each from afzal electronics abid market.. they ripped me off for sure..gree display centres dont havr this model as these r for dealers only..last night i went to afzal electeonics dha and randomly asked for the price.. by the time i was walking out he quoted 73k for 3 units.. i didnt even bargain slightly! So if anyone is looking to buy one i think you can gey them down to 70 or 71.
The vent noise is slightly irritating.. the vent movement of right/left makes a unique plastic "click" sound which comes after almost every 20 secs or so. It might go away if you lock the movement, havent tried it so cant tell.
I dont know how much amperes its pulling as i dont have any meter attached to it.. which is probably the most imp point evweyone wants to know..if i do get the readings, ill share them asap.
