Review: Gree LOMO LM4 1.5 ton
My office is a big 700sqft Hall at top floor gets baked by direct sunlight form 3 directions. I have put a thermometer inside and it gets as hot as 35-38C depending on the temperature outside.
I installed this AC a month ago to see if it could bring down the temperature to 28C, if not I planned to put another 1.5 ton. 28C is cool enough for me.
I have been testing it for the past month and here's what I have found so far. It has great throw, specially on turbo mode. I can feel the cool air on the other end of the hall which is 25ft away. It generally brings down temperature by 4 degrees in one hour. It consumes 7.5 amps max at 230 volts, so about 1700-1750 watts.
Today when I turned it on, temperature was 35C, it brought it down to 32C degrees in first 25 mins, by 35th min it was 31C, by 45th it was 30C and buy 60th min it was still 30C. I doubt it will go lower than this, but I'll update this post if it did.
I definitely need another AC. I think a 2 ton inverter will be a good option. So there will be two ACs, one conventional 1.5 running at full load all the time, 2nd a bigger 2 ton inverter to quickly cool down the room and then slow down maybe to keep 28C.
