My experience is exactly the same. I'm pretty sure this model is the best buy in PK.
I must add that the more amps your model draws, the more powerful it is, in other words, you get maximum capacity. For example those people who have stated that XYZ 1.5 ton AC starts at 5A must understand it is a 1.0 ton AC labeled as 1.5 ton.
Only panasonic and Mitsubishi heavy industries have continuously provided 10A compressor capacity for 1.5 ton models and 12-13A for 2.0 ton.
Most companies have labelled 8A compressor as 1.5 ton model and 10A compressor as 2.0 ton model
In other words, if you buy a 1.5 ton Panasonic or MHI for Rs. 60K,
It will have the same cooling as a 2.0 ton premium XYZ of rs.80+K because both will draw 10A.
So for a 10A compressor rating, for most brands you have to pay for 2.0 ton label, while for Panasonic, MHI, you have to pay for 1.5 ton label. Same capacity, different labels and prices.
Bigger label will always have higher price so most companies do this trick.
Secondly, Panasonic inverter ranges from 1A-10A i.e. 10X variation,
While most inverters go from 2A-8A i.e. 4X variation
