I have read a lot of guys are saying the Inverter AC stats getting lower Ampare once the desired temp is achieved which is incorrect.
Inverters produced for instant cooling and massive saving but due to misconception people keeps on saying the Inverter will start saving after achehiving the required Temp.
The fact is, Once you start your ac it will sense the temp difference between room and outside temp which the outdoor unit is installed.
If you set temp 26 and out side temp is not very hot then the inverter ac will sense that it is not supposed to work harder to obtain desired temp thus it will work slowly therefore it will consum lower Ampares.
Incase you set the temp 16/17 and outside temp is 40 plus the inverter ac will sense it needs to do a lot to achehive desired temp thus it will work on full throttle to obtain 16/17 temp which it cant obtain so it will keep running on full power and will consum much more power than 26 temp.
Let me tell you guys the ampare starts coming down within 5/10 minutes under designated conditions
Let me know you guys if i am wrong.
