I've ran into this odd issue with a 1 ton inverter.
It used to cool perfectly fine, would drop room temperature to even 23-24c.
Now, even if it's set to 20-22c mode, it can barely drop room temperature to 27.5-28c.
In both cases outside temp around 31-32c.
What could be the reason?
Previously if set to a low temp on AC like 22C, I could feel the compressor run at max speed/amp until set temp is reached.
Now it drops amp after just reaching room temp to 28c..when AC temp is set to as low as 20-22c.
So, max cooling isn't reached. Already checked gas, it's fine. Cleaning also done.
What else should I check? Indoor unit/evaporator coils are dark in color (blue/black, something like that). Not sure if it's called blue fin or something else.
Things to check/replace?
