what is your room size ?
Sent from my GT-I9505 using PW Forums mobile app
I thight he is talking about non inverter model
Sent from my QMobile A6 using Tapatalk
I bought it from Alfatah electronics Lahore. https://www.alfatah.com.pk/acson-awm15jalc15c
You can check the prices of 1.5 ton using below link:https://www.alfatah.com.pk/online-shop-for-split-air-conditioner-in-pakistan#/specFilters=25m!#-!246&manFilters=26
Few post earlier you're against the inverter one now it seems you're going to purchase inverter AC strange
OK good. Seems this is a split ac but still very good price for a top rated brand. How come it consumes 2.5 amps at 28 degrees if it is a normal split AC and not an inverter one?
I did not mention that it is consuming 2.5 amps. On 20c temp, it usually consumes 5.5 Amps.
My room size is 25 * 30
No i was never against it ..... actually the issue is low voltage and it needs proper 190 to 200volt at first jump start. planning is to buy a bigger AC like 2 ton and then it may give some saving like consumption of 1.5Ton AC
Hahaha exactly what came to my mind. Our brother here was proper anti inverter I remember a long post from him when he bought this non-inverter AC. Good to see a change of heart
Oh OK. My mistake. I read the second post after your one and mistook it as one written by you. Have you checked its amperage at let's say 26 degrees ? Is there any difference at all in power consumption?
For 750 sqft room even 2 ton ac wont work,i fear.
You should consider a cabinet 2.5ton AC for such a big room
Getting orient ultron 19k7 1.5 ton inverter for 59k. Is it worth the buy? Gree inverter for 74k 18ciph. The shopkeeper said both are same. No issues or complaints in any of them. Suggestions needed plz
using PWz app
If budget is not an issue u should go for Gree
Budget is an issue. I m already going high from 50k budget of mine so 74k is out of question. Btw is anyone using orient? The shopkeeper told me the consumption is almost same as gree. Would appreciate suggestions plz
If you dig up whole of this thread then u might come to know that many users are using orient and no one complains yet so u can go for it without any hesitation
Thank u highly obliged
Orient inverter seems to be the best choice in the under 60 thousand range.
Anyone have experience? How nuch ampere PEL energy saver window ac 1.5 ton consumes?
Sent from my SM-J700H using Tapatalk
Sorry for an of topic question but can someone plz recommend a good smart 32" inch led within the range of 35? Its quiet urgent
