The guy at Technowash tried compound already, made no difference.
If it's something in the clear coat, then I shall be claiming paint warranty from KIA.
Then it has to be claimed in warranty.
Once go and ask from ahmad bhai at luxe auto spa
I would suggest to make a quick decision as another hike is around the corner
Anything in clear coat should take no time in removing through compounding if properly done.
But what is the paint itself is damaged?
A question to the owner of Sportage FWD does the door panels have light in them or those just reflectors? the one inside the doors.
Those are just reflectors.
When to expect the booking of sportage? how much raise is anticipated
It would be very unique case as clear coat is a top layer protecting the color. I can't imagine paint getting any damages while clear coat is intact.
3-5 lacs increase seems evident.
has anyone here tried the Sportage's SECRET Engineering Mode? is there anything in it to be unlocked or feature that can be turned on or off?
What's that? Never heard
This looks like Sportage has a root mode where options can be turned on and off through the main computer?
as the name suggest's it's a SECRET Mode that can be accessed through your infotainment system (with some invisible key press's) where you have different options that can be turned on and off (used to do this with other vehicles as well (German/italian cars) where we were able to turn some features that are disabled by the manufacturer. other cases we used OBD to achieve same results.@Oblivion yes
Oh. Never knew. I wonder if that is available in Sportage
I think just like the AC fresh air automatically turns on which is solved by pressing series of button
well i don't have one to try it on but i will post if i get my hands on one (even then the infotainment sys in internationally sold sportage could be different then the PAK one), @waleed80 maybe try googling the combinations and see if you can access it?
Yes, I went inside the Engineering Mode a few times but could not make any progress regarding updating the software to add new features. By the way OS on Sportage's head unit is Android base but everything is either locked or can't be accessed
If anyone has accessed the engineering mode does it have the speed lock enable option?
