Not that I've seen. It has metal brackets inside for reinforcement and the bumper just fits up into the fenders and other places through clips. The clips on the bumpers require grommets through whereas the clips around the radiator area are push-in clips.
Alright. Thanks
I remember they came in 2 shapes, the goofy one had big hollow styrofoam inserts for the front bumper finisher, while the usual one didnt.
I think the goofy looking ones were cbu units
No spacer for rear bumper as well?
These were all CBU units. They all have plant and country code of japan in the VIN.
How much is reserve fuel capacity of lancer?
8-9 litres as per owner’s manual.
@Xulfiqar Got the car showered. The job finished at 5Pm today. After how much time its okay to touch the car and wash it or get it detailed?
There is one more thing that i have discovered. When i turn the switch on the fuel pump keep running and does not stop. What could be the reason?
Can this pressure regulator get serviced or replaced?
No,
Someone has hotwired the fuel pump, most probably cng ustaad.
The fuel pressure regular is a passive mechanical device, it has no electric connection and cannot sense or relay any data.
Yes, and when the FPR goes bad, it just increases pressure in the injectors so all of a sudden one day the car starts consuming more fuel with no visible causes such to most owners and mechanics. Happened with me too. After a long time I found out about the fuel pressure regulator and replaced it. Running fine now.
Ah yes. CNG was installed in the car. I will get it checked by the electrician.
Should i go for Chinese IACV from Ali Express or Kalbi from Bilal gunj? Both price almost the same.
Neither
Buy new genuine or if buying used make sure its a working one. Sometimes the ecu is also damaged in the part which controls the idle rpm.
This is how you can test your IACV to get a definitive answer. You can use this test to check any kabali IACV as well. I would recommend getting a new IACV (OEM or Ali Express).
https://www.evolutionm.net/forums/evo-general/527736-iac-testing-question.html
