I recently installed chines headlight in my chines bike and very impressed with the result same like HID, but i found issue with the light was it cannot perform low beam function, it seems to be manufacturing fault because i found most of the other same headlights having same issue too, so i trace its power circuit and found two smd diodes faulty, so i remove and replace them with 2 (1N4001) diodes that are very common. Now they perform low beam function with lower 3 leds and high beam function with all 6 leds. The diode with brown wire is for angel eyes (so called) or for two small led ( i replace these blinking leds with white ones).
