LED means (light emitting diode) so today it is very commonly used every where....some people like to use LED in cars and bikes...for good look....so for those lovers some lesson about led ...how to use it...
LED operates on 1.5 volt to 3 volt maximum more then 3 volt can damage LED so for that purpose RESISTORS are used to limit the current and voltage....
first lesson to glow led....
this circuit shows that 9 volt battry connected to led through (470 ohm) resistor(i recommend to use 1 kilo ohm resister inted of 470 ohm) ....no matter 1 kilo ohm resistor can also be used insted of 740....
if battry is 12 volt so 1 kilo ohm resistor must be used insted of 470....in same circuit....
led has positive and negative terminal so if led dosn't glow in one direction then change it direction.....
2ND LESSON TO GLOW LED
1:this is the physical shape of LED and leg direction + and -.....
2:this fig show symbol of led it is used in electronics to represent LED...
3:this diagram shows how to use led with 12 volt battry....
..now u can make every type of LED circut if u want more led then add more led to circuit along with 1 kilo ohm resistor....as shown in fig 3
4:this figure shows resistor of 1 kilo ohm...resistor have no direction u can use it in any direction..
NOW EXPERIMENT AND ENJOY U WOULD LEARN IT SOON...
