for newbies liana's maintenance schedule.
copied from some,so posting here as well.
Maintenance Schedule
Maintenance Schedule Under Normal Driving Conditions
NOTE:
β’ This interval should be judged by odometer reading or months, whichever comes first.
β’ This table includes service as scheduled up to 90,000 km (54,000 miles) mileage. Beyond 90,000 km
(54,000 miles), carry out the same services at the same intervals respectively.
Interval
Km (x 1,000) 15 30 45 60 75 90
Miles (x 1,000) 9 18 27 36 45 54
Months 12 24 36 48 60 72
ENGINE
Drive belt β β I β β R
Valve lash (clearance) β I β I β I
Engine oil and oil filter R R R R R R
Engine coolant β β R β β R
Exhaust system β I β I β I
IGNITION SYSTEM
β±Spark plugs When
unleaded
fuel is used
Vehicle without
HO2S
Nickel plug β R β R β R
Iridium plug β β β R β β
Vehicle with
HO2S
Nickel plug β β R β β R
Iridium plug Replace every 105,000 km (63,000 miles) or
84 months
When leaded fuel is used, refer to βMAINTENANCE RECOMMENDED UNDER SEVERE
DRIVING CONDTIONβ in this section.
FUEL SYSTEM
Air cleaner filter Paved-road I I R I I R
Dusty conditions Refer to βMAINTENANCE RECOMMENDED
UNDER SEVERE DRIVING CONDITIONSβ
in this section.
Fuel lines and connections β I β I β I
Fuel filter Replace every 105,000 km (63,000 miles)
Fuel tank β β I β β I
EMISSION CONTROL SYSTEM
β±PCV valve Vehicle without HO2S β β I β β I
Vehicle with HO2S β β β β β I
β±Fuel evaporative emission control system β β β β β I
NOTE:
β’ βRβ : Replace or change
β’ βIβ : Inspect and correct, replace or lubricate if necessary
β’ For Sweden, items with β± (asterisk) should be performed by odometer reading only.
β’ For spark plugs, replace every 50,000 km if the local law requires.
β’ Nickel spark plug : BKR6E-11 (NGK) or K20PR-U11 (DENSO)
β’ Iridium spark plug : IFR6E11 (NGK)
MAINTENANCE AND LUBRICATION 0B-3
Interval
BRAKE
Brake discs and pads (thickness, wear, damage) I I I I I I
Brake drums and shoes (wear, damage) β I β I β I
Brake hoses and pipes (leakage, damage, clamp) β I β I β I
Brake fluid β R β R β R
Brake lever and cable (damage, stroke, operation) Inspect at first 15,000 km (9,000 miles only)
CHASSIS AND BODY
Clutch (fluid level, leakage) β I β I β I
Tires (wear, damage, rotation) /wheels (damage) I I I I I I
Suspension system (tightness, damage, rattle, breakage) β I β I β I
Steering system (tightness, damage, breakage, rattle) β I β I β I
Drive shaft (axle) boots/Propeller shafts (4WD) β β I β β I
Manual transaxle oil (leakage, level) (I : 1st 15,000 km only) I β R β β R
Automatic transaxle fluid Fluid level β I β I β I
Fluid change Replace every 165,000 km (99,000 miles)
Fluid hose β I β I β I
Transfer oil (4WD A/T) (leakage, level) I β I β I β
Rear differential oil (4WD) (leakage, level) (R : 1st 15,000 km
only)
R or I β I β I β
All latches, hinges and locks β I β I β I
Power steering (if equipped) I I I I I I
NOTE:
β’ βIβ : Inspect and correct or replace if necessary
0B-4 MAINTENANCE AND LUBRICATION
Maintenance Recommended under Severe Driving Conditions
If the vehicle is usually used under the conditions corresponding to any severe condition code given below, IT IS
RECOMMENDED that applicable maintenance operation be performed at the particular interval as shown in the
following table.
Severe condition code :
A : Repeated short trips
B : Driving on rough and/or muddy roads
C : Driving on dusty roads
D : Driving in extremely cold weather and/or salted roads
E : Repeated short trips in extremely cold weather
F : Leaded fuel use
G : β β β β β
H : Towing a trailer (if admitted)
Severe
Condition Code
Maintenance
Maintenance
Operation
Maintenance Interval
β B C D β β β β Drive belt
I
Every 15,000 km
(9,000 miles) or 12 months
R
Every 45,000 km
(27,000 miles) or 36 months
A β C D E F β H Engine oil and oil filter R
Every 5,000 km
(3,000 miles) or 4 months
β β C β β β β β Air cleaner filter β±1
I
Every 2,500 km
(1,500 miles)
R
Every 30,000 km
(18,000 miles) or 24 months
A B C β E F β H Spark plugs
Nickel spark plug
R
Every 10,000 km
(6,000 miles) or 8 months
Iridium spark plug
R
Every 30,000 km
β B C D β β β H Wheel bearings I
Every 15,000 km
β B β D E β β H Drive shafts and propeller shafts (4WD) I
Every 15,000 km
β B β β E β β H
Manual transaxle oil, transfer oil (4WD A/T)
and differential oil (4WD)
R
Every 30,000 km
β B β β E β β H
Automatic transaxle fluid R
Every 30,000 km
Automatic transaxle fluid hose I
Every 15,000 km
NOTE:
β’ β±1 : Inspect more frequently if the vehicle is used under dusty conditions.
