nice work bruv!keep it up!
thxs
updates
you cut the plastic to fit the holder?
yes i did ,,,do this
1-first mark holder shape on paper as shown in pic2-cut the paper3-stick it on light4-now just mark that shape on plastic5-remove the paper and u will see marks6-now remove that area it won't be very clean cutting n no need to clean just put holder and cut if required.
(you have to cut the plastic )
Hopefully it help .
Got it!BTW here is an opened tail light.I was just curious to know that is it the circle on the right where the bulb will sit after cutting the plastic?
yes - thats the blanked hole from the plastic mould.
Do a favour to yourself - get a can of white paint and paint the reflector white, Black light reflector is like making biryani with bad rice and equally bad meat cuts like spare ribs or tail
I have also installed a halogen bulb for the reverse light - it provides great illumination but you need a relay as the little switch on the gearbox cannot take the load. You dont need to worry about heat as the duration is very short. You dont run the car in reverse all the time.
No dear, bulb is fixed.Its not hanging from anywhere. All you need is cut little plastic, and then squeeze the holder in. use little ELFY if you feel is not tight enough to fix it properly.
Connect the Wires!!
Lolz. Yeah sure. Will make a proper Biryani!!!
That to me is not open, its broken. Why you pulled the light off like that? Now you need silicone stuffing>?
Why not open the entire light juts as my bro did??
small things that make a huge difference... great work
Yes, shows love and care too
plz post more pic of ur diy its diff to open glass ,have u manage to open it without cracks i guess its origional light nt after market
glass mean plastic n m also planning to install small bulbs in front light wll be use with parking
Lol!Thats not my car,Its just a random shot of a Khyber with a broken tail light.
Lol! I get your point.I will do it when I open the lights.BTW this one is not my car.
Interesting!If possible then do post some snaps of it.
Will post pics of my cousin's Khyber and DIYs that my brother did to it!!
Banda hai bhai ye lolz .. !
Some Interios Cleaning which I did today.
